new type Rs!! screeching noise!
I didnt hear anythign in the second vid?
have you checked and made sure all your power and ground connections are tight?
have any extra RCA cables laying around you could swap in and test?
what brand headunit?
all i can hear in the second vid is static, possible group loop?
its not working still......its a vented box i plan on getting a ported one when i get money.
vented and ported are the same thing. it could be port noise from being a horribly designed and built box. i'd have to hear it, but you can get some pretty wicked noises from not having enough port area, or being way off on height to width ratio.
mmmm doesnt sound like iti can have the volume all the way down
i had subs in these box before. the box does **** but not that bad
if it does this with the volume down, i'd say wiring. ground or rca wires. ground loops can be a whining noise that raises with the rev of the motor usually. but if you have the crossover filter where it should be on the amp, it shouldn't be able to play any higher frequencies, thus also filtering alternator whine.
alright so i hooked up a little 300w amp to one of the subs for a sec and it hit. so that means my ground and remote and power and everything is good. right? so i think its the amp then right?
xbatxattackx
xbatxattackx
california
xbatxattackx
