new type Rs!! screeching noise!
so what do i need to do! i have different subs and amp hooked up right now and it works fine.
When you're trying to discern what your problem is you do it one step at a time. I know you hooked up a 300 watt amp and it worked so we're down to the amp and borderline user error.
Put the Alpines back in your car with the amp that you are running now. If the sound is gone then I would once again wire up your old amp but change nothing else. Literally wire the original amp up right next to the new amp so there is no chance you wired something wrong. On your old amp set everything to 0, make sure you're plugging RCA's into the input of the amp and not the output, set your LPF to off.
What is the outcome?
you won't damage the subs with a 300 watt amp. Actually the amp you were trying to use can only be wired to 1 ohm which won't work or 4 ohms. So if the amp you put in after is 300 at 4 ohms, there would be no difference in using that amp and the one that doesnt work. You need a amp that does minimum 1000 watts at 1 ohm i would say
Don't you love when you spoon feed someone exactly what they need, and all they do is dance around a avoid it?
"use the old amp to troubleshoot"
"but I don't wanna hook up the old amp"
YOU'RE USING IT TO ****ING TROUBLESHOOT.
xbatxattackx
xbatxattackx
california
xbatxattackx
