New Build 6.5Cubes 18" Sub 6" PSP Ports Hatchback
well if there is a problem with the sub fitting we will take care of it.
if i modeled the sub correctly it should clear with a 1/2" to spare atleast.
one way or another we will get it to fit in there.
~Magick_Man~
if the port is pvc you can heat it up where is too close or touching the sub and give it a slight bend. it will still retain the same port area just in a different shape which i doubt will hurt tuning or performance.
hmm, we will have to keep that in mind.
i am 90% sure it will clear but if it doesnt i think we will replace the piece of wood that the ports are mounted on.
but we will see which seems better at the time.
~Magick_Man~
Quakerroatmeal what kind of Integra you have? I must warn you lol, once you put that heavy box in you will a difference with your acceleration. I have an LS with a 12w6v2 with original specs box and my car is as slow as a turtle.
Its a badass box and i cant wait to see it fully setup
Update:
Well I finally got the recone and everything. I checked to see if it fit, and it clears no problem! *WHEW*. Here are the updated pictures of the recone.
The FI Recone package
Basket/Softparts
Blank Dustcap
RE XXX Dustcap
Test fitted in the box (the sub is now fully assembled/reconed, just put it together and threw it in the box for the pic)
And to the above post. I have an Integra LS. It drives just fine, I Just stomp on the gas.
quakerroatmeal
quakerroatmeal
Dallas, TX
stayTUNED
    Jun 24, 2026
    Jun 24, 2026
