Need Info On JL w6v2 Help!
What type of enclosure are they in? That will determine the power needs.
Wire them to 4 ohm and bridge a two channel. It makes no sense to wire to 1 ohm and run the piss out of an inefficient Class A/B.
ok so i measured my box. it measured 30.5w X 16L X 13.5H in. Do i need a different enclosure?
Run it through a box program and see what the internal volume is.
Also, don't buy a 1 ohm stable amp...it's not the right amp choice. This forum is rife with bad ideas, that being one of them.
Tell us your budget and we will help you find a nice two channel that will give you enough power at 4 ohms bridged.
ok i got my new amp today....and i need help setting up the filters and the gain and what not......HELP PLEASE....ive never had a subsonic filter on an amp before and i have no idea what im supposed to set the LP filter and bass boost(which i think i should leave as low as it goes) but IDK HELP!!!
johnnyvolcom5
XBL TAG xL BLAZE ix
johnnyvolcom5
Minnesota
southcdogg12345
