Need help with custom vented box for 12" sub
I might consider going for your slot design after all seeing how difficult it is to find the right port because my trunk just *****.I just didn't really understand that port size you made up, 5.25 x 5.25.
Am I correct that this is what you mean by that:
thats the general idea except you will use the wall of the box as port walls as well. so you only make a 5.25 L bent and put it in the box to make a square using the box itself for the other two port walls. This saves a lot of airspace.
let me pm you some stuff.
So basically, this is correct?
on my phone.. im positive you could get away with one 4"
Well I can get away with a 4 inch but it would have to be 17 inches long. That's 43,2cm.
Those ports don't exist sadly.
EDIT: I could try to make it like this, maybe I could get away with the 17 inches in length if I use this style.
Well I can get away with a 4 inch but it would have to be 17 inches long. That's 43,2cm.Those ports don't exist sadly.
elbows cause a lot of resistance and you lose a lot of overall performance. Defeats the purpose of an aeroport from the start.
[quote name='Jeffdachef']elbows cause a lot of resistance and you lose a lot of overall performance. Defeats the purpose of an aeroport from the start.[/QUOTE]
@Jeffdachef @papermaker I found one on accident this morning, 4" diameter and 17.9" long.
What do you think?
Try entering these in to torres. For the depth I took the avarage between the 2 different depths to get the same volume as the wedge design that I'd use.
Btw, just in between.What do you guys think of these bad boys:
www.audiodesign.de/downloads/datasheets/Hifonics/ZX1254.pdf
Hifonics ZX1254 500 watt RMS
ESX Audio SX1240 500 watt RMS
Perhaps those are alternatives? The second one is cheaper so budget wise I'd be looking at that but. Just say what YOU think.
that port should work. thise amps kinda ****..
Those are woofers not amps //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Aygodriver1212
Aygodriver1212
Amsterdam
Aygodriver1212
