Need help choosing an amp
He’s saying since it didn’t go into protect at .5 then it looks like the amp will be harder to kill. I think it’s the opposite in that the amp isn’t protecting itself like it should (could be wrong).
I also thought that aswell but Idk it was killing my 1200w daul xpr540s quick I killed 2 bridging parallel and on the amp
Step up to a better brand and you’ll be happier.
Tbh Thats why I looked up dynos, to see which brands are liars I was actually thinking ignite was gonna be lying lol but nah it did great but I was also thinking boss which surprised me too but I seen daul lies and then which got me thinking my daul wasnt even pushing out as much power as I thought and my subs were actually hitting pretty hard with the daul. But then again it died I guess what Ima saying is what brand do you recommend that isnt going to straight up die if not the ignite?
There’s a little more to it then numbers on a dyno. Like what has already been mentioned quality components how well the board is put together overall build quality sound quality do they stand behind their product 🤔 there’s a reason the ignite is as cheap as it is. It’s a throw away amp.
Really you should be a little more patient and throw a little more $ at it when you can and get something better. Make sure your electrical is up to the task quality wire correct gauge clean install etc.
You’ll be happier in the long run and have a reliable system or you’ll likely be in the same boat later on if you go with the cheapest sh;t you can find and end up spending more money in the long run.
Ignite, boss, dual are all flea market/wal mart brands. You can get so much better for just a little more. The Soundqubed S1-1250 is $179 and will murder those other brands. Taramps is a solid brand as well
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
Kewizzle
Kewizzle
Omaha NE
OldFartAudio
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
