Need bass setup advice
tree7363
I have an 04 Gmc Sierra crew cab and was wanting to add some bass seeing how the bose speakers I have now don't come close to cutting it. The only boxes I can find for my truck are ones that go behind the rear seat (There's about half a foot of clearance back there). The boxes seem to only be for either 2 10's or 2 12's. I'm leaning towards the 2 12's seeing how I prefer the low rumbling type bass sound over the punchy and loud. Here's what I found seems would be best based on 15 minutes of googling:
Amazon.com: ASC Chevy Silverado or GMC Sierra 1500 Non-HD Crew Cab Truck 2001-2006 Dual 12" Subwoofer Custom Fit Sub Box Speaker Enclosure: Car Electronics
Amazon.com: Pioneer TS-SW3001S4 12-Inch Shallow Step Up S4 Subwoofer: Car Electronics
Amazon.com: Pioneer GM-D8601 Class D Mono Amplifier with Wired Bass Boost Remote: Car Electronics
Would this amp work with these 2 subs? Also would it even sound good seeing how it's so tight back there behind my seats? What wires do I get? I don't need anything special here, just some solid subs that will add some umf to my music and will last me for some years to come. Any suggestions at all would be appreciated.
If they fit the box why wouldn't it sound good? I just want the 12's seeing how I don't like the sound of a punchy bass.
My HDS210s sound really good. I like the low deep bass too, I don't care for the punchy bass either. I listen to hip hop/rap. The sub size has nothing to do with it.
The box size matched to your sub is the issue yes you can put a pair of 12s behind the seat. Will they give you what you want bass wise ? Prolly not. That's why I said 10s
145
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
450
347
tree7363
tree7363
United States
mylows10
    May 16, 2024
    May 16, 2024
