Need a little help, please.
Can anyone help me find a fit kit for a 2001 Jetta? I've been looking all night and haven't found one yet. I found a couple at Crutchfield.com but when I add them to the cart it says they won't fit. Also the universal one I found on eBay is the same one as on Crutchfield, so that won't work. I'll keep looking though.
it should definatlly have a kit. type in 2001 volkswagon jetta dash kit on ebay and crutchfield.com im sure youll find it,
You have a double-din OEM right? The only "kit" for a Jetta is a din-sized pocket, you would install it into the bottom of the radio cavity and install the radio into the leftover din-sized hole above it(or vice-versa)..Metra makes a pocket, part #88-00-9008
If you have a single-din OEM the you don't need any kit at all, just a harness and antenna adaptor..
Go here for kit/harness info:
http://www.metraonline.com/fit.aspx
You have a double-din OEM right? The only "kit" for a Jetta is a din-sized pocket, you would install it into the bottom of the radio cavity and install the radio into the leftover din-sized hole above it(or vice-versa)..Metra makes a pocket, part #88-00-9008If you have a single-din OEM the you don't need any kit at all, just a harness and antenna adaptor..
I'm not really sure. It's my friends car and I haven't looked at it yet. I saw the pocket kits, but I don't know if he needs it. The only other mounts I seen was what looked like just a trim ring that goes around the HU for a single DIN, but Crutchfield says that it won't fit.
If it is a single-din OEM, just lock the cage in and slide the HU in..If it is double din, then grab one of those pockets and you are good to go..Easy Peasy //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Rideredder
Rideredder
Cornell, IL
nuugen
