Need a design for two Audioque hdc3.10
  • 5
evilmonstertruk
Premium Member
Premium Member
1,144
Maryland
Something like this. It's in a 2005 Expedition. 1500rms.
Max depth (front to back)- *48
Max height (top to bottom)- 36
Max width (side to side)- 49
I got a design from Buck for my Sundown z12v3 but he stopped. He was going to do this one but I understand. Hope he's ok and if he's sick that he gets better.
Model
HDC3.110
Woofer Size
10"
F(s)
41 Hz
R(e)
Z(max)
Q(ms)
6.999
Q(es)
0.374
Q(ts)
0.355
V(as)
9.16 liters (0.717^ft)
L(e)
mH
n(0)
M(ms)
grams
C(ms)
mm/N
Sensitivity 1W/1m
84.43db 1W/1m
BL
Xmax (Peak to Peak)
36mm
Magnet Weight
300oz
Coil Diameter
3.0"
Coil Length
54.229mm
Usable Throw
68mm
RMS Power
1500W
Peak Power
4500W
Displacement*
0.11^ft
Mounting Depth
7.625"
Circle Cutout
9.437"
Let me know.
Thanks
Sent from my LG-H910 using Tapatalk
Have you searched on Sound Qubeds site yet?I didnt actually see any enclosures for subs up port up for a pair that would generally work well in an suv,but the Sq Ft measurements are there if you know how to calc it up/find a enclosure download.
I like subs up port up myself..Subs up, port rear generally what most like to run..but deff on what you really like.
This is for my brother. I think he got that design from CAF. Is there anyone that can build me a design like that with those subs and dimensions?
Should work well enough in DD spec box as well if you like any plans on their site. If you're not chasing 10ths I don't think port back port side or port up will make much difference.
I think it's more the look of it. He just wants it to sound proper. 1500rms for those two subs isn't quite enough but should be ok.
Box design and building just isn't something I have looked at. When work dies down and I get my new house with a garage I'm going to learn.
489
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Buck has been my go to since I got into builds, currently he’s unavailable and hopefully back at his passion soon (for privacy I’ll leave it at...
156
evilmonstertruk
Premium Member
Premium Member
evilmonstertruk
Maryland
evilmonstertruk
pfft
    May 1, 2024
pfft
    May 1, 2024
