Need 2k watts
ma hk 4000d, little over 3600 at 1.. Just turn it down, will sell for 200, around 100 to get fixed. I can send it there and have them send it to your addy. Only a week turn around time.
Why are you selling it ? what type of condition is it in?
9/10 cosmo
10/10 working
DO NOT NEED IT. Looking to trade it for a sub and enclosure, but if I sell it I can just buy the sub and enclosure. I have a Funkin Audio mf 400 to power a new sub. I have a Ford-F150 XLT truck and it is too much power for ne thing in this truck, plus I work in it.
9/10 cosmo10/10 working
will this amp work as a daily driver w/o a HO alternator?
Yes it will.
You shouldnt need ne thing extra to use this amp. I got it on a trade and the guy used it to power a RE SX 12" on a stock 2000 Grand Am alt.
Yes it will.
wow that was one high powered 12...is this amp really rated accurately?
From cardomain.com
Ultra Compact Design
Efficient Class D Circuitry
1 Ohm Stable Operation - 2100W RMS at 1 Ohm !
Dual Sided Circuit Board
Surface Mount Device (SMD) Technology
Variable Low-Pass Crossover
Variable Bass Boost
Switchable Phase Shift
Variable 15 - 40 Hz Subsonic Filter
Switchable Input Sensitivity Mode (100mV-2V / 2V-8V)
Line Outputs
Master / Slave Switch with Data Link
Included Remote Level Control
RMS Power: 1200W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.05 %
Bridged RMS Power: 1500W x 1 @ 2 Ohms
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 15-250 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: n/a
Shipping: 13 lbs
Warranty: 6 years
From 12Volt.com:
IQ3KD.1
Max power, 2 ohm 2200w x 1
Max power, 1 ohm 3000w x 1
RMS power, 4 ohm 1200w x 1
Bridged power N/A
Signal-noise-ratio >100dB
THD N/A
Dimension 6 1/2"W X 2.0"H x... 16"
I guess just let me know. I have some others interested, but no one has stepped up as of yet, so it's still avail. until it is traded and/or payed for. I have to get to bed, but I'll check back tomorrow morning adn I'll be here tomorrow night as always.
TC2k15x2
TC2k15x2
Debary FL
TC2k15x2
