Need 2k watts
ma hk 4000d, little over 3600 at 1.. Just turn it down, will sell for 200, around 100 to get fixed. I can send it there and have them send it to your addy. Only a week turn around time.
Why are you selling it ? what type of condition is it in?
9/10 cosmo
10/10 working
DO NOT NEED IT. Looking to trade it for a sub and enclosure, but if I sell it I can just buy the sub and enclosure. I have a Funkin Audio mf 400 to power a new sub. I have a Ford-F150 XLT truck and it is too much power for ne thing in this truck, plus I work in it.
9/10 cosmo10/10 working
will this amp work as a daily driver w/o a HO alternator?
Yes it will.
You shouldnt need ne thing extra to use this amp. I got it on a trade and the guy used it to power a RE SX 12" on a stock 2000 Grand Am alt.
Yes it will.
wow that was one high powered 12...is this amp really rated accurately?
From cardomain.com
Ultra Compact Design
Efficient Class D Circuitry
1 Ohm Stable Operation - 2100W RMS at 1 Ohm !
Dual Sided Circuit Board
Surface Mount Device (SMD) Technology
Variable Low-Pass Crossover
Variable Bass Boost
Switchable Phase Shift
Variable 15 - 40 Hz Subsonic Filter
Switchable Input Sensitivity Mode (100mV-2V / 2V-8V)
Line Outputs
Master / Slave Switch with Data Link
Included Remote Level Control
RMS Power: 1200W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.05 %
Bridged RMS Power: 1500W x 1 @ 2 Ohms
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 15-250 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: n/a
Shipping: 13 lbs
Warranty: 6 years
From 12Volt.com:
IQ3KD.1
Max power, 2 ohm 2200w x 1
Max power, 1 ohm 3000w x 1
RMS power, 4 ohm 1200w x 1
Bridged power N/A
Signal-noise-ratio >100dB
THD N/A
Dimension 6 1/2"W X 2.0"H x... 16"
I guess just let me know. I have some others interested, but no one has stepped up as of yet, so it's still avail. until it is traded and/or payed for. I have to get to bed, but I'll check back tomorrow morning adn I'll be here tomorrow night as always.
TC2k15x2
TC2k15x2
Debary FL
TC2k15x2
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
