Now based on this information I have a couple questions.
1. With my alternator listed above, would my car be able to handle pulling 500/900 watts RMS from the respective amps listed.
2. I don't want my speakers to play bass. I want the subs to play bass, I want the speakers to play everything else, do I need to have a 5 channel amp to achieve this, since my HU doesn't have a crossover, or does the subs amp handle this?
3. For the budget price of no more than $300 what other combination of subs, and amps could I look into?
4. Will the subs listed be able to handle 450watts RMS if I choose the bigger 900 watt RMS amp?
5. Will the subs be noticeably louder with the KAC-9105 at the same volume vs the KAC-8105, or is it just better efficiency at that point?
6. Is the calculation 500 watts / 12 volts = 41 amps correct, will 500 watts RMS pull 41 amps, and will 900 watts RMS pull 75 amps from the alternator?
7. What else should I know, anything, as I want to be as educated on the subject as possible, so I don't have to worry about something going wrong once I do purchase the system.
