- Thread Starter
- #961
Yes, I totally understand the "water through a pipe" analogy. "Big 3" WIRING ONLY solution MAY perceptibly alleviate my instrument lights dimming problem, but a higher output alternator would probably do so better and for less cost in $$ and work! And your "getting a larger 'Water Bottle'" analogy better fits a higher capacity BATTERY!The Big 3 upgrade would also alleviate the dimming without purchasing a new alternator. Your trying to **** too much "water" through a "straw" that is too small. Get bigger "straws" and you can drink more from your already full "Water Bottle". Getting a larger "Water bottle" will be useless because your current "straw" cannot empty it. Input/output. Your input is fine but your output is limited by wire size. Understand that "Electrical Engineer"?
Fourier analysis on your menu? ;-)
John Kuthe...
