Monster 10" subs...
We should have a SPL contest with NEW woofers that cost under $70 bucks shipped, it'll be awesome.
that would be pretty cool....that would be 3 pup 12's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif but I'm sure the pups wouldn't be allowed in the contest....due to unfair advantage
I ordered a cuspid wo-1008 made offer of 48.xx after shipping total was $80 even. Will pull tsp's and do some power handling tests, excursion tests, blah blah lol. Ordered 5 minutes ago estimated arrival between 16th and 23rd. Ill keep you updated.
TSP's folks, sub arrived today. Not shabby at all, low Xmax, prob 15mm one way linear, but overall its a dang nice woofer for the price. Single 4ohm coil, highest BL I've tested on a single coil driver.
Here's TSP's (Pre-Break-In) for those waiting, I haven't played with power handling yet but I will, and when I do I'll update asap!
Re = 4.2251 ohms
Fs = 45.5401 Hz
Zmax = 81.6094 ohms
Qes = 0.4541
Qms = 8.3170
Qts = 0.4306
Le = 3.2476 mH (at 1 kHz)
Diam = 210.8200 mm ( 8.3000 in )
Sd = .035m^2 ( 54.1061 in^2)
Vas = 10.4992 L ( 0.3708 ft^3)
BL = 23.1539 N/A
Mms = 201.3674 g
Cms = 60.6545 uM/N
Kms = 16486.8184 N/M
Rms = 6.9278 R mechanical
Efficiency = 0.2052 %
Sensitivity= 85.1394 dB @1W/1m
1.4net @ 33Hz for an f3 (anechoic) of 29.5Hz, only needs 27sq" port area for a vent mach of .04, 36sq" for .03 (idea) max output plotted to be 113.21dB (pre cabin gain) @ 34Hz on 600 rms so expect a ~133dB in car in my recommended enclosure. Still have yet to test power handling, will get to it asap. Stay tuned, this is going in my scion TC on 500rms in my recommended enclosure, if it does good I'll up power to 1600 for some fun.
After some power testing using 25Hz sine-wave free-air it's thermal limits are definitely its short fall, I have 1K @ .08%THD to give it, and @ 1" P-P it begins to heat up, nothing bad, prob no more than 140 degrees F, Xmax is looking more like +/- 13mm. There are gaps around all the columns, (8 x 4 stack 2.5" x .5" thick so 2" total height of magnets) and plenty of under spider venting but no air movement around the coil to keep it cool. Coil turned out to be 3", I told someone 2.5" but after a bit of rigorous measuring it is in fact 3" lol. Coil is short enough so that it cant reach the back-plate so no bottoming out issue, thick windings, looks to be 8 layer but the wire is very small gauge, 24awg maybe smaller so that is the subs limiting factor. Tinsels are small gauge and woven through the spider so thats a lil bit of a bummer as well. Motor has serious potential for fun high BL custom drivers but its glued and screwed like crazy. Thats where I stand now and I'll keep the masses updated, I know everyone is just dying to get the down low on these $80 shipped 9" diameter motor 10's lol. Push terminals accept true 12awg wire easily by the way.
Newest TSP's after prob 5 hours break-in and tested while warm for during play tsp's
Re = 4.0462 ohms
Fs = 38.5535 Hz
Zmax = 80.2152 ohms
Qes = 0.3742
Qms = 7.0436
Qts = 0.3553
Le = 3.3223 mH (at 1 kHz)
Sd = .035m^2( 54.1061 in^2)
Vas = 13.4602 L ( 0.4753 ft^3)
BL = 23.9602 N/A
Mms = 219.1560 g
Cms = 77.7606 uM/N
Kms = 12859.9775 N/M
Rms = 7.5371 R mechanical
Efficiency = 0.1937 %
Sensitivity= 84.8894 dB @1W/1m
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
mossberg385t
