MONO or STEREO (2nd time)
  • 2
marcopolo
First of all, I apologize for language mistakes, I come from Slovenia (Europe)!
I am wondering about the wiring of my amp. It is 2-ch. and it will be used in bridged mode to power my sub. I don't know whether I should run the signal RCA's from my head unit separately , or should I wire them togeter (left&right + together and left&right - together) like the picture in the manual shows? The amp should probably mix the chanels internaly, but I am affraid the sub would get only the signal from one chanel. Any idea?
Thanx in advance!
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Run the pair of RCAs to the amp.. It will do the work for you. No it wont run just left or right it will combine the two into one channel if you set the amp to mono..Hope that answers your question.
Mike
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
533
I get it. I'd never run a tone through at full tilt to test just how much they can take before it goes all willie nelson either 🤣
72
5K
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
marcopolo
marcopolo
Slovenia, Central Europe
mykeys
winkychevelle
    May 24, 2024
