MM4000.1 1 ohm daily
Will a MM4000.1 run 1 ohm daily?
  • Yes
    Votes: 8 44.4%
  • No
    Votes: 10 55.6%
  • Total voters
    18
You can always try it. You will see the amp stressing before anything happens most likely.
If it isnt what you like, then do something about it. If it happens to work in your case, go for it.
That's why your dropping to the 9's!My shit don't drop below 13 at full tilt.
i only dipped into the 9s when i had the amp running only on the batt for testing this amp is pretty **** efficent! does real good. with my poor *** ele it dont drop under 11. when i wire my subs 2 ohm each channel my voltage barley drops at all!
well at 2 ohm each side you'd be at 4 ohm so you shouldnt be dropping at all lol..
Yeah... People really have a boner nowadays for running amps below their minnimum impedance and at double their RMS.
Dont get it.
blame the 20.1 for that one.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
.08 ohms?
come on now
terra
terra
Yes
tooloud4tv
