Matching 2 different subs same watts/ohms
Yes it will work. Won't be great results but it does work. Just because a sub is the same ohms and rms does not mean that the suspensions are the same and they have similar characteristics. Give it a shot, if your happy great. If it loses output and sounds bad take it out
Ive done it in the past..just having fun trying stuff out..with a pair of tens.They did fine in separate chambers,got lots of box noise in shared chamber.Wasnt bad butthey did fine.I had approx. 20 + subs sitting around at the time and dual sub boxes laying around.So I experimented.Its best to run same subs same size as possible same model on same amp to get the box correctly made tuned to function to the subs potential to get the best out of the subs chosen
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
looks like it will work just fine. this amp would work just as well if you want to save a little money. I run one of these and a 2k as well. Both...
2012 Seat Alhambra Deck: Grundig GX-3800 (already unhappy with this and planning to switch it out for a Kenwood unit) Door speakers: Kenwood...
19
Tyrionmanister
Tyrionmanister
Columbus, Ohio
LosIsATool
slater
    May 2, 2024
slater
    May 2, 2024
