Low Ohm light - Help!
wong05tsx
Oakland, CA
I can't figure out what's going on. All the speakers are still working.
I have a JL 300/4 powering Hertz HSK165 and Polk db6500 coax and I just noticed today when I was tweaking the tuning that the low ohm light was on. The amp now gets hot a lot faster.
Both fronts and back is 4ohm, and the JL is 4ohm stable.
Any ideas?
^ a short in a wire or in the amp?
ugh...
so if i keep using it, it may damage the speakers then or just blow the amp?
i just picked this **** thing up off craigslist like 3 weeks ago too, it was working fine when I hooked it up
sweet made it into someone's sig =)
ugh...
The short is probably in the speaker wiring somewhere.
also, where can i get these ohm's repleced and how much would it cost?
This all has to do with us messing with the noob. Thus the //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif in my post. It like a tub of elbow grease or blinker fluid or something along those lines.
x2
we were j/p
although, i think i am running low on blinker fluid
well thanks for clarifying. i'll try to single out which speaker wire is shorted
..or if I disconnect all the wires and just power up the amp and the light is on, then that'd just mean the amp is screwed rather than a short?
brb.
379
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
573
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
4K
wong05tsx
wong05tsx
Oakland, CA
J31Rob
    May 12, 2024
Brendon Jenness
    May 11, 2024
