jetta2vr6
All the wiring kits I have seen have the fuse holder close to the battery. Does it matter if it is close to the battery or the amp?
and by 'no', he means 'yes'. if you are going to put a fuse right before the amp, 10 feet away from the battery, dont even bother using a fuse at all. If theres a short somewhere before the fuse, a toasted amp will not matter when your truck is on fire. everything F.A.M. said was true, though. -scottOriginally posted by F.A.M. No, not really, you can have it anywere you like. But based on the info you just got, use your best judgement. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I have to disagree with the 1st part. The in line fuse can't possibly protect the amps. It's simply to keep your power wire from becoming a heating element in the case that it's shorted to the chassis.Originally posted by F.A.M. The fuse box services 2 functions, to protect the amp/amps and to protect the car.
So what you are saying is that if someone who does not use an in-line fuse, and that their amp does not have a built in fuse (yes there are amps that do not have built in fuse) and lets say that they have a bad ground, that their amp will be fine?Originally posted by n2audio I have to disagree with the 1st part. The in line fuse can't possibly protect the amps. It's simply to keep your power wire from becoming a heating element in the case that it's shorted to the chassis.
My point exactly, the in-line fuse protects BOTH the wire and the AMP.Originally posted by fantomas how does the mtx 81000d become protected? it has no built in fuse...but requires a 150 amp inline. if the fuse only protects the wire, whats the point of building amplifiers with fuses built in? -scott
A lot of higher priced amps have circuits built in for current protection (like mine). Power down, they reset. More times than not, if you have an amp with on board fuses, and you do something that pops one, your amp just went up in smoke, but possibly saved your car from doing the same.Originally posted by fantomas how does the mtx 81000d become protected? it has no built in fuse...but requires a 150 amp inline. if the fuse only protects the wire, whats the point of building amplifiers with fuses built in? -scott
No, not what I'm saying.Originally posted by F.A.M. So what you are saying is that if someone who does not use an in-line fuse, and that their amp does not have a built in fuse (yes there are amps that do not have built in fuse) and lets say that they have a bad ground, that their amp will be fine?
I think not.
If you say so.Originally posted by F.A.M. My point exactly, the in-line fuse protects BOTH the wire and the AMP.
Not true, if your amp has a bad ground, then the current flow will be impeded. This will result in the amp working harder to draw current, which will cause the amp to heat up and possibly overhead. I have seen this happen to plenty of amps in ghetto rig cars over the years.Originally posted by n2audio No, not what I'm saying.
Not an applicable analogy anyway. If you have a bad ground the current path is restricted -- Less current, less chance of power problems, just less output from the amp.
Sorry, one more comment. What's happening there isn't thermal shutdown, in that case the amp cannot draw enough current to supply the output being demanded. That's not thermal shutdown, it's current fault protection. Happens to me all the time when I'm working on something in my car with the stereo playing. After an hour or so of running only off the battery the amps power down b/c the voltage being supplied is too low.Originally posted by F.A.M. Not true, if your amp has a bad ground, then the current flow will be impeded. This will result in the amp working harder to draw current, which will cause the amp to heat up and possibly overhead. I have seen this happen to plenty of amps in ghetto rig cars over the years.
AmenOriginally posted by F.A.M. Just run an in-line fuse, and keep it close to the battery.
Nuff said, onto new things. [/b]
You mean to tell me that you dont disconnect the battery before working on your car...? ...and then you let the battery die....? -scottOriginally posted by n2audio Happens to me all the time when I'm working on something in my car with the stereo playing. After an hour or so of running only off the battery the amps power down b/c the voltage being supplied is too low.
