Lexus SC400 install (Morel, Scan Speak, Mag's)
Coolness!! I'll be there unless it's 30 degrees and raining like last time. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Hey, I have a comp tomorrow and it may well be 30 and raining, and I will be there, don't be a wuss Nick //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Yeah, but that's normal up there. Down here it's nice and sunny and warm. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
It got to the mid 60s yesterday, it was really nice out.
I've done some more work on the Lexus recently. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll start with the remote progress.
I first took the volume control out of the car and started dissecting it and the 3sixty's remote. You can see from these pics how I just tore apart the volume control section of the volume control, as I need the climate part to control the HVAC in my car.
The volume control came apart pretty easy, but I was really hesitant to snip the tiny little circuit board traces and/or connections out of old habbit. However, the volume control wasn't going to be used ever again in this car and you can buy used assembly's on ebay for cheap.
The metal "spider" carrier had to have the middle hole hogged out to accept the 3sixty's knob, but other than that the unit fit right up to it. Thankfully RF supplied extra nuts and washers to attach the remote to another face so I used that to secure the remote to the board.
And then I noticed that the shaft of the 3sixty remote BARELY fit inside the white plastic housing. What that meant was I couldn't drill a hole in the factory black extension to go over the 3sixty's knob. So what I had to do was sand down the factory plastic shaft and make a tiny blade so it would fit inside the 3sixty's slot.
I also had to cut slots in the outter housing to accept the 3sixty's board and also cut a hole in the back of the unit to accept the new remote's board.
But now it all works! The old volume control now controls the subwoofer level of my system!!!
And now for the false floor section.
I initially cut out a piece of wood that would fit over the two supports on either side of the subwoofers that was all one piece. However, you have to hinge it in order for it to fit inside the vehicle. So I took the solid piece and cut it on one end to make a hinge.
I had my sign guy print me up a Lexus logo and then I used that logo to trace out the Lexus emblem on the piece of wood. After some jig saw work, I had a Lexus logo in the middle of the piece of wood. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I bought carpet from Parts Express that was/is pretty close to my original carpet color and cut it out using the factory floor piece as a template. I then put the pice of wood on top of the carpet for a test fit.
The blue tape is to outline the edges of the wood so when I put contact adhesive down I don't go overboard. I then coated the wood and the carpet with contact adhesive and put the two pieces together.
After that, I stapled the carpet to the back side of the board and then followed it up by stretching grille cloth around the Lexus logo opening.
Thanks guys. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm going to start working on flush mounting the amps pretty soon. And of course I'll post pics of that.
Then I need to start working on the grilles for the SS's and also working on the internals of the door pods to tame a resonance I have at 250 Hz.
Thanks! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Wanna help me flush mount the amps this weekend if it's not pouring down rain? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
*edit* we can also post a frequency response graph for James Bang while we're at it...even though frequency responses don't mean anything to him. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Unlikely the antenna connection is compatible, and even worse - they are awful. They are the worst sound quality of any car audio component...
908
Anyone? Anyone? Looking at the audio control d 6.1200
Electrodynamic
Knows nothing
Electrodynamic
Mooresville, NC
Electrodynamic
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
