Least gauge wire you would use?
Keep in mind that length is a factor here as well. If you're doing a long run (>20 feet), you should use one size larger. It doesn't hurt to use a wire size that's larger than necessary, but it will usually cost more and can be more difficult to install.
Power Wire:
10 gauge: ~35 amperes
Class D (~70% efficiency) -
Class A/B (~50% efficiency) -
8 gauge: ~55 amperes
6 gauge: ~87 amperes
from the sticky
16 gauge: ~8.7 amperes
8 ohms -
6 ohms -
4 ohms -
3 ohms -
2 ohms -
1 ohm -
How is 16awg good when it says its good for 75 watts at 1 ohm here?
16 gauge: ~8.7 amperes8 ohms -
6 ohms -
4 ohms -
3 ohms -
2 ohms -
1 ohm -
You can still use it I think, but there would be power loss and maybe heat build up. I'm not sure, but regardless I would use at least 10 gauge like I said earlier. You won't get much power loss at all using 10 awg. How long is your run from the amp to the speaker?
THXdts
THXdts
Maryland
THXdts
