starting troubles
mtlhead
So my car is having problems starting...but it will start
equipment:
0 awg in knu konceptz, big 3 as well
stock batt, stock alt
american bass 100.1 amp
15" RE SX running at 1 ohm
voltage stays high while driving, i dont normally blast it around here, stays around 13.5-14.2
any reason why my car isnt starting properly? something taking power while car is off?
Have you tried unplugging your amp and sub after you shut the car off for one night? This may help eliminate that possibility. You know, it may just be your starter wearing out //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
what year car? i just replaced my starter in my 94 grand am 160k on it.
with old original starter it took a bit of cranking for it to fire, but now with new starter the engine fires pretty much instantly. but i also put new plugs and all of that nonsense in which also helped
pop out the plugs and check em out, hell just replace them and also if you arent to keen on changing oil very often do that. new serpentine belt? do some engine maintenence
mtlhead
mtlhead
Columbus, Ohio
Crzy
