Knu RCA's & Speaker Wire
i have 2 new kicker si205 (0.5m) and 3 new/3 used for a week si21 (1.0m). $5 per cable, $5 shipping (without the packaging) in the conus for as many as i can fit in a small flatrate box.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
780
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
779
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
670
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
798
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
917
ewoevo
ewoevo
FL Panhandle
nineball
    May 24, 2024
    May 23, 2024
