Know nothing need advice
Tried to pm you bigblank but box is full. I'm 3 hrs south of you in champaign.
u are new so i'll tell u bigblank test new amps, post video reviews (u can see the threads here) then sells them.. that 4 channel is nice too..
Right now Sonic Electronics has an awesome 5 channel for cheap. The NVX 5-channel is only $179.
The next decision is how much space are you willing to forego for the sub. Ported is my preferred but you can get a much smaller sealed box and still have some good "thump". A single twelve in ported configuration is going to take up 1.5-2.25sq ft of volume, pending sub selection. With your budget there are a bunch of options. Here is an example of what I may purchase on a budget system.
Converter - Audiocontrol LC6I $120
Amp - NVX 5 channel $179
Custom ported box - $125
Wiring kit - $80
Sub - Sundown SA-12 $220
Fronts - JBL GTO's $75
Rears - Same $75
Install fees - $500
Total'ish - $1,374
Some corners could be cut and certainly more could be spent. Install price varies greatly in areas.
Sent from my SM-G950U using Tapatalk
I wouldn't suggest a big 12" sub....maybe a smallish 8" sub might suit him better as he stated he just wanted a little bit better sound. A single 8 takes up less space too.
Could also do a shallow 12 or 10. One that takes up a low amount of cu.ft space. Elantra's can be somewhat tight on space...
Hmm...something like a Dayton Audio sealed box sub....smallish and takes up little space.
I am a huge fan of the Daytons. Another low cost subs that just impressed me completely...the NVX. Just out two into one of my work trucks. Awesome.
Dayton HO's would be good... Small box friendly for sure and can hammer lows.
I also like for a budget and shallow the Pioneer Shallow subs. I have one here and while not a JL Tw3, it's a pretty darn good sub in a small enclosure.
Just my 2 cents...
Adding a quality sub and amp (650ish watts rms rated) run me around $600 not counting install cost (doing the install myself). Single 15 on 650 watts rms amp on oem deck and speakers. Thats LOC, RCA, FUSE, BOX, SUB, AMP etc... (custom box will be $100’ish more)
Just a fyi... bottom end of things to coplement oem and least impact on elec sys. Thanks to the forum members for advice...
yeah blanks mono amp with sealed dayton would be good even a 10 lot better than just reg speakers.. keep factory til u see how they sound that saves u more $ up front anyway..
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
964
Yeah, I plan to run them in my workshop. I haven't gone through them or anything but they startup and run just fine. I don't see any strange spike...
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
287
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
242
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
431
hordeall
hordeall
il
BOOMINGRANDPA
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
