New Install Suggestions
thesir72
VA
After many years of 'wanting' to ... I've pulled the trigger, and bought a complete new system from Crutchfield. Money is always an issue, I want a decent sound w/o breaking the bank. So here's some info on the hardware..
HU: JVC - JVC KD-R880BT
FRONT SPEAKER: JVC CS-DR620 (6.5 X 2)
REAR SPEAKERS: JVC CS-DR6930 (6X9 X2)
SUB: Blaupunkt GT Power 1200w (12"x 1)
AMP: Phoenix Gold M25
everything installed beautifully, no issues with fit ... except needing 90 degree RCA adapters. I've only had it installed for about a week, still tweaking EQ and various effects. But my main issue right now is I think I'm getting too much bass response out of the 6.5's and the 6x9's ... some tunes you can hear those speakers really starting to distort (even at lower volume).
What is a cost effective way eliminate bass frequencies from these speakers? I've read a little on bass blockers, most of these articles were about the ineffectiveness of bass blockers until you reach higher dB's ... Any suggestions appreciated!
Thanks, -thesir
amp or hu don't have hp xover? if so turn it on set it at 80hz..if not.. if u woulda ask us 1st we would have steered u to a hu with xover on it ,mine was $119 and has like 50 audio adjustments..
btw bass blockers work but aren't great..i just looked at your amp yeah if u don't have hp xover on hu u should sell that and get almost any other amp they all have xovers..
Are you using the Phoenix Gold to power the speakers? If so, did you set the gain properly? The gain knob is not a volume knob.
probably running the amp to his sub, esp since he doesnt have another amp listed
hu does have a h/p l/p
i agree with boomingrandpa on this, set the x-over to either 80 or 100 hz, should fix ya right up
your deck says that it has selection points at 80, 90 and 100. Try it out on any of those and see how it sounds to you
thesir72
thesir72
VA
youdoofus
