Just blew a fuse...
yeah my old setup had the same problem. it was fine for about a month and then my amp started acting up. weird isnt it? there's not many threads like this but this **** happens, hah.
Omg
Rarely does a blown fuse come from a bad groud
Usually it means your power cable is exposed somewhere, therefore it's grounding itself
If the ground is fine, and it only pops when you turn up the volume, then maybe get a bigger fuse
I use an 80 for my setup, only time it blew was when the power wire came out of the amp and touched the bare metal inside my trunk
how large is your wire, and how many watts (RMS) is your amp
lolll
problem solved
get like a 60-70A fuse, everything should be fine
but I'd really really suggest upping your 4 gauge to a 2 or higher if you're running 1300 watts rms
Could adding a bigger fuse void your warranty (if its still under warranty)?
Why not take it back where you got it and see what they say?
Also, I was under the impression that amps are designed with a certain fuse rating for a reason. If you are blowing it under normal conditions, there is probably another problem. Adding a larger fuse will just allow more current to pass to the problem, and probably more current than the components were designed for. The bcae1.com section on fuses scared me away from using larger fuses since I don't know as much about amps as whoever designed it.
I've only had fuses blow on me twice time...once was how I found out I had a leaking gasket in the trunk lid. the second, (i'm embarrased to say) was wiring the terminals backwards in a hurry... in both cases, I'm glad the fuse fried before the amp...
yeah, for fuses on the amplifier
he was talking about the fuses on his power cable, in which case a larger fuse is basically just harder to blow, needs a lot more current to blow than a smaller fuse
in which case, I run 80 for my 1080 rms setup, if he has only 40 on his 1300, I don't see a problem as long as it doesnt blow up
a fuse even up to 120 will still break when the power cord comes into contact with car metal or something
changing the fuse to the power cable bigger will allow mor current flow to the amps meaning once the amps receive too mcuh current the amp fuses will pop ending up in the same sh!t. upgrade ur wiring dude u have 1300 rms and u running a 4 run that 0 man. the fuse is to protect the wire not so when the amp is asking for more current and the wire cant supply it then pop ya digg.
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
946
Thanks for all the help guys I'm going to buy a new sub, looking at some of the suggestions u guys gave. I have a small sealed box now but will...
41
4K
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
671
SAG3
________
SAG3
Kauai, Hawaii
jmoreno150
