Featured Recommendations for 150A fuse between alternator and batteries?
Voo Doo
CarAudio.com Newbie
Hello all,
I recognize I am out of my league with my car project -- but I think the Car Audiophiles probably have the experience with a similar situation… and have advice....
I want to connect two identical 12V AGM batteries in series, and use a single 160A fused switch between the batteries and the alternator. The alternator is a 160A 1-wire unit, and I will be using 1/0 battery cable the whole way.
Attached is a pic of the 150A fused switch I have in hand (from Amazon -- see attached pic) that I was thinking to place back by the battery. I like the idea that I can use this as an anti-theft device, HOWEVER, somehow I just do not feel that the fuse is adequate -- small in/out terminals, and kinda chintsy feel to the switch and reset button.
Will this fuse work, or is this a known major problem area? This is the item on Amazon (https://www.amazon.com/dp/B0CC9DYBDH/?tag=caraudiocom-20 )
Are there any comments about this switch, OR any recommendations for a switch that can go from one input (from the alternator) and split into 2 outputs (to each of the 2 batteries) -- or any other recs?
Thank you.
Just run the wire from the alternator to the first battery, then run a wire from battery 1 to battery 2. Trying to split the wire middle for each battery just adds another connection point and a point for failure.
I used one of those for the longest time on a 1200w system with zero issues.
FYI, never run the batteries in series. That will bump you up to 24v.
I was about to ask the same thing. Why would you want to wire the batteries in series. But then you said you were connecting them to the same alternator, so I figured you got series and parallel mixed up.
What's the amp draw from the batteries going to be, and what gauge wire are you using?
Voo Doo
CarAudio.com Newbie
Voo Doo
Houston TX
Old_Slapper
