just a small question please...
  • 2
mofugga
Jax, FL
hey i'm putting a new apline type R in my car with an old 10" of mine. if i have a two channel (really old, not even bridgable i think..no switch) amp running about 150 to each, should i just connect each sub's wire to their on channel in stereo....i think that's right, but i need confirmation
is it possible to have this DVC type R on one channel of my amp and my SVC 10" on the other without any problems? or can i only put another SVC sub on...hope not
also, when installing a brand new sub int a sealed enclosure box...what is the process...i mean it can be just screw in the sub and connect the wires with a snap...especially since the type R is a DVC. how and where do you connect the wires?
How do you have to connect the wires? do the slide in something or do you have to burn them on or use a soldering iron or what?? i need to know Thanx!
Originally posted by mofugga hey i'm putting a new apline type R in my car with an old 10" of mine. if i have a two channel (really old, not even bridgable i think..no switch) amp running about 150 to each, should i just connect each sub's wire to their on channel in stereo....i think that's right, but i need confirmation
what are the ohm rating on BOTH subs
FIRST make sure the box is for that speaker
depends on the ohm load you are tring to create
solider or some have push type connectors
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
  • Locked
676
  • Locked
COMPLETED Small 4channel amp
I'm really tempted to grab a 4k db 🤔
19
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
mofugga
mofugga
Jax, FL
mofugga
maylar
    Jun 2, 2024
    Jun 1, 2024
