Just a few questions.
CrAiZ3
1. How should I go about wiring my HC2400. I have it as a second battery in the back and have done the big 3 upgrade. Should I buy a battery isolator or run it in paralell with my Walmart battery? I don't plan on letting my system run for long periods of time without the car being started.
2. I am currently on a tight budget. As of now the only amp I have for my door speakers is this:
http://www.carreview.com/mfr/rockford-fosgate/amplifiers/PRD_3893_1806crx.aspx
I have 6 speakers, 2 sets of sony xplod 5 1/4 and a set of JL 5 1/4. How should I go about the wiring for this?
You are adding an extra batt and you don't even have a sub?
But to answer your question yes you will want an isolator or a solenoid to separate the 2 batts.
I would think you would want a 300a or larger isolator. That one looks fine.
That Fosgate is a 2 channel so at most you can have 4 speakers on that amp.
not good to have two diff batteries... it's good to have the same model and have them be the same ages... if not, your crappy walmart battery could put a drain on your kinetik
Which would sound best?
the 4 xplod's running off the amp (The rear speakers)
the 2 JL audio's running off the amp (Front door speakers)
And how should I go about wiring them.
CrAiZ3
CrAiZ3
Pittsburgh, PA
CrAiZ3
