JL sub problems
Master69
i have some wuestions about these jl subs im picking them up off of a trade and i want to know which 2 will be easier to fix..obviously the 2nd will be easiest but what would be harder to fix 1 or 3?
1: Has 1 broken tinsel at cone. Measured both VC and it shows 3.5ohms. Overall in good condition. Just don't have time/skills to fix the tinsel lead.
2: Has 1 broken tinsel lead near the connector. Very easy fix and all VC measures 3.5ohms.
3: Works fine, has a 1 inch approx tear in the surrond. Can be patched up or surround can be replaced easily with a replacement kit.
262
347
The best shallow that I've heard is the JL by far. One good regular 8" sub on a 1K would probably be all that you need. Two 8's in 1.5 cubic feet...
492
424
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
327
Master69
Master69
Burlington, Iowa
Dirtrider4eva
Brendon Jenness
    May 8, 2024
    May 8, 2024
