is this sub good
so i picked up 1500 Series
the dd 1512a 2ohms
never really got to play it loud since i dont wanna fry it..or at least wanna break it in
anyone know how long i need to break it in?
and also should i wire it down to 1 ohm on the cab1600 or leave it at 2 ohms?
and should i pick up this box
https://www.amazon.com/dp/B0013MWT12/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=31PJJ5LP5CP79&coliid=I1J0XXHGZQRKKG&psc=1
since right now the box im using is a pre fab that pretty much just fits the sub and has a small port one of those universal box that you can pick up from bestuy.. would i hear a big difference with that box loud/sq? or should i get another box?
Have a custom one built or get a design and build it yourself. Never look at amazon, ebay or bestbuy boxes again. Anything pre made just translates to horrible results also that sub doesnt match well with your setup. Should have gotten a redline 700 series 12 instead
sounds like a plan.
is the sub i got better than my power akoustik? and or is it better than this dd
600 Series
im trying to see whats the difference besides the redline is mass produced in china and the one i got is from america
1500 Series
i appreciate your guys help slowly making my way of knowledge through this all.
another question for my direct leads anyone have a video on how to wire them..for now i just twined them together and electric taped it for now.. do i need 10 gauge speaker wire and shrink wrap etc? anyone have a video or some sort or a walkthrough?
the dd 1512a 2ohms
You cannot wire 1 sub to either 2 or 1 ohms, it does not work like that.
What is the VC setup on that sub?
Your choices will normally be either 4 or 1 ohms
whats vc?'
so i can or cant wire the dd to 1 ohm?
i thought 2 ohm subs can wire to 1 or 2 ohms
its 2 set of voice coil with direct leads
sounds like a plan.is the sub i got better than my power akoustik? and or is it better than this dd
600 Series
1500 Series
I'd go with a 3512 if you want it from that line. Thats basically the base starting line for DD's standard line IMO.
The redline 700 series is much better for your setup because its a 3 inch voice coil. Heck even the 600 series is a bit better with a 2.5 inch voice coil.
Vc stands for voice coil. A dual 2 ohm coil can be wired to 1 ohm by wiring parallel, or can be wired to 4 ohms by wiring in series. Definitely try to get a custom ported box for that sub and you will be very impressed
hey thanks for the links! i like to have lots of options ill take those in consideration!
as far as my sub im just liking the fact that i have a dd compared to my old power akosutik but no one is really telling me that its better so far.. lol someone give me some reassurance that i dropped 300 on the dd and its better than my old power akoustik lol please.
gary the real mvp for making me feel like i done the audio world a favor and chose right! yeah i was thinking of just looking on there i mean im sure that specs is better than my pre frab box im prob losing out on a lot of potential
DD partnered with Atrend and sells boxes for DD subs. The dealer should be able to get those boxes. They are not a bad route if you cannot find a builder
://www.atrendusa.com/digital-designs-12-single-vented-spl
ekah
ekah
hawaii
garychoffmann
