Is this design Moe made a little off?
SHiZNiLTi
I allways thought that you had to have an equal port width?
*edit* the port area is 6" on the front of the box as shown in the orignal sketch by Moe, but the inner port width is off, it's 5.25 and should be 6"
You don't want less that the width of the port. Aeroports often times are a lot farther from the backwall than the diameter of the port, especially if they are external.
wtf are you talking about?
And to the OP...the port is clearly labeld at 6" wide, where do you get 6.75" from? Either the paint drawing is wrong or he went .75" too long on the port piece...
EDIT: Just build to the numbers, it adds up. he just put a line in the wrong place in the drawing...
the 6.75 is the distance from the inner part of the side wall the outer part of the port piece. look at the other numbers. the 29.75 is from the inner part of the port piece and the inner part of the other side wall. 29.75 + 6.75 =36.5 add in the 2 pieces of .75 side walls and the exterior width is.....ahah 38 inches. Get it?
oops,
Yes your right for the 6.75 being wrong. It is a true 6" of port width. I screwed that up.
But, the other one is definately wrong.
19.25 + .75 = 20
26 - .75 = 25.25
25.25 - 20 = 5.25
So the port is incorrect in the cutout sheet, it should actually be 18.5" long not 19.25"
You completely missed my post that explained whats wrong with the picture...not the plan...
Do not change the cut-sheet, it is right. the only thing wrong with it is a misplaced line on the picture...do I have to draw it out?
Ok if you did that then the top port width inside the box would be 6" and the fornt port width would be 5.25.
Just take the .75 off the front...
Didnt even notice the front was labeled wrong. Just saw the dimensional and assumed it was the same...
Hey, what kind of spray on the amp rack is that? I had a customer what a fleckstone style paint job and I was clueless as to which one was best on wood. Did that stuff come out very good? How much prep did you do?
http://www.plasti-kote.com/plastikote/homefash/template.jsp?searchcode=FLE&product=Fleckstone
The Fleckstone went on very easy, Goes on thick, don't shake the can. I put some clear over it to prevent it from flaking off. I like the texture thought it's cool....
here's another pic of it...
SHiZNiLTi
SHiZNiLTi
Scottsdale, AZ
PowerNaudio
