is running 1ohm stable amp at 1.5ohm ok?
  • 5
To clarify, you can always run an amp at a higher ohm load than it is rated, but it will decrease the power by a factor similar to the inverse of the ratio of the rated ohm load and the actual ohm load (assuming the amp wasn't built to support it's rated power at a certain range of resistance).
(rated ohm load/actual ohm load) = (actual power/rated power)
If that makes you more confused, if your amp is rated at 400w at 1ohm but you run it at 1.5, you'll get a lil over 250w out of it (theoretically).
I calculated this by using (1ohm/1.5ohm) = (actual power/400w) ---> then solve for actual power.
1/1.5=(2/3) or .6667, which you can then multiply by the 400w to find your actual power output.
.667*400w = 266.667w, which is again a theoretical value, but something to go off of.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
698
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
mariomazyck1991
mariomazyck1991
charleston,SC
Bettr n' Revrse
