Is it possible to wire a dvc 4 ohm to run at 4ohm...
yeah but u can't run interior speakers off the other channel... because it will be 350w @ 2 ohms as well... plus... it'll be set for lowpass signal just like the sub...
you actually can wire the sub at 4ohms, you just run a set of wires from the amp to one 4 ohm voice coil, and then another set of wires from the same channel or a different channel to the other 4 ohm voice coil, and WAHLAH... you have a 4 ohm load from a dvc 4ohm sub...
if he ran a set of wires from the same channel to both coils... then he would end up with a 2 ohm load
ok then that may be so, but say you have a 2 channel amp, and you have a dvc 4 ohm sub, ok.... say you run a coil on each channel... so that would be a total of 4 ohms..... correct, so that is how you wire a dvc to 4 ohms...
About the post that i said before, scratch that.... the amp "would" read 2 ohms, but the amp could only push out as much as it can at 4 ohms, becuz it is going into a 4 ohm application.. correct?
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
420
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
663
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
colt325e
colt325e
Sactown, California
PeterTHEpiper
pfft
    May 1, 2024
pfft
    May 1, 2024
