Inverting A Sub
5ummer5
13
UK
Hi,
Does it make much difference to the output of a sub if it is inverted? It will be in a ported box. Coz due to having no space to mout it im thinking about just doing a fibreglass box and inverting it.
Thanks.
Hi,
Thanks.
inverting doesn't affect sound/output.
but what i don't understand, is if you don't have enough space to mount it in, then how would that change inverting it?
if you need 2cubic feet of box space with a regular mount, you'd need 2cubic feet of box space minus the displacement of the sub, but then the sub will still be taking up the same ammount of space outside the box?
it seems to me like it would take up more space inverted than not.
sometimes you cannt get the depth to munt the sub but you have plenty of width/height
Im my case it is JUST about wide enough for the sub with space for depth and height. The external width of the box must be 280mm max and the cut out hole has to be 24.77cm which when you make the box out of 18mm mdf leaves u a total of .3mm under the size. So when i construct the box it wont fit, its hard to explain really but i am jus going to invert in and make the box out of fibreglass to make sure it fits ok //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif if i cant figure it out in wood! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Thanks for the help
5ummer5
5ummer5
UK
iamamp3pimp
