Installing new deck - Power wire question
Hi everyone,
I bought this new car deck, an Alpine MP3 player. While reading the instructions, something was funny with the notice they put in for the power wire.
They say I need to connect the yellow wire (wich has a 20A fuse on it and choke coil) directly to the battery.
The specs say the deck needs 14.4 v to operate and since Alpine has a "tinny amp" built into the deck it may need up to 17.2 v
So because of that, I have to pass a cable directly to my battery (bye-bye easy install right) ? Now, what would I need like kit to do that ? Hope it's not complicated ?
Thanks in advance.
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Thanks in advance.
I don't think they mean to actually go to the battery. They mean the constant 12v wire in the harness. I don't know about that 17.2v, because you really can't get more than 14.4 out of your alternator(stock).
yep, I've seen the same instrustions in an alpine manual, they have the pictures of the battery and everything, but they mean the constant 12v power wire on ur wireing harness, and if they dont then it doesnt matter because it works neways!
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
thecheesypoofs
thecheesypoofs
Montreal, CA
warmonster
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
