Installing Amp and sub on factory system
  • 2
Glenni92
Norway
Hello, i have a electric vehicle with factory amp and sub which kinda ****. i have a dynabel monoblock and ground zero 12" that i had in all my past vehicles. and in these i also changed the head unit.
in my current car i cannot change the head unit since i would lose alot of the functions regarding its a electric car.
can i install the amp and sub like you would normally do? only thing i know i have to do diffrent is to use a high low converter to connect the rca's to the head unit. can the factory amp and sub just be there like they are now?
I'm not an expert but doesn't sound like it would hurt to try. It doesn't sound like too much work if it doesn't work. Come back and tell us how it went. What kind of fuse comes with the factory equipment? Will it be good enough with the new stuff?
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
The formula is Square Root of your target Wattage Multiplied by Ohms. 50Wx4Ohms=200. Square root of 200 is 14.14. So 15v AC is your target.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
546
Glenni92
Glenni92
Norway
Nate154
    Jun 15, 2024
    Jun 15, 2024
