Installing 2 1-Farad Capacitors with MMATS Amp
  • 2
james33440
FL
Okay, currently I have a 4-gauge power and ground connection with a 100-amp circuit breaker. Shortly, I will be receiving a MMATS D300HC amp for my HCCA 12's. I only have a 1-Farad cap. However, I will probably get 2 new 1-Farad caps with bussbars. Now, what should I do? Should I just go with the 4-gauge power to the cap and then to a fused distribution block and connect to the power on the amp? Or, should I use the 4-gauge power to a "T" distribution block and then use the 2 4-gauge power cables to the cap and then to a fused distribution block and finally to the amp?
Originally posted by james33440 Okay, currently I have a 4-gauge power and ground connection with a 100-amp circuit breaker. Shortly, I will be receiving a MMATS D300HC amp for my HCCA 12's. I only have a 1-Farad cap. However, I will probably get 2 new 1-Farad caps with bussbars. Now, what should I do? Should I just go with the 4-gauge power to the cap and then to a fused distribution block and connect to the power on the amp? Or, should I use the 4-gauge power to a "T" distribution block and then use the 2 4-gauge power cables to the cap and then to a fused distribution block and finally to the amp?
try to get the cap as close to the amp as possible if you can. no distros
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
james33440
james33440
FL
chris229
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
