Indivdual speaker on/off switch possible???
no no no, Im running the 15 on a monoblock, I want to have 2 substages basically. either 4 6.5" subs running off the 5 channel or the 15 off the monoblock and I was wondering if I could put a switch between the 5 channel amp and the 6.5's to turn them on or off and I planed to have a switch to on the 15" subs amp.
I cant put a switch on the 5 channel itself cause itll cut my highs out
look, sub output is going to have to go from sub amp to the Memphis, so if I cut the subs off at the HU I wont have any bass. All I want to know is can I put the toggle switch inbetween a amp and the speakers without any issues
thats the smartest unnessary comment Ive seen all day:rolleyes:
You can run seperate remote wires, and switch each? Idiot.....
read Idiot.....
Why not use one of those push button things...my little brother has one on his home audio stuff. I am sure parts express sells the "selector"
Basically, one set of RCAs go into the the selector, and two sets go out. You would just press "a" or "b". But that would mean you would need differet amps.
I think this would work, just run the sub out from HU to the selector and the two sets to the Memphis and sub amp
ok well when i had my old set up i just put a toggle switch on my remote...since the remote tells the amp to turn on...wouldnt that work??? i kinda dont understand where your going.....you have 2 amps 1 for your componets and the other for the 15?? right?? if thats right then just put a toggle on the sub amps remote and should work like a dream
anyway questions been answered, thanks for everyones time though
DDSC
Wang-aholic
DDSC
Jackson, MI
DDSC
