If money weren't an issue
Can I fit this horn in a vehicle?
image.axd
pair of critical mass ul12
zapco 4k amp ( 2x 9.0 in same case)
hybrid audio legathia 3 ... 4 ... way
audison bitOne
some tru audio or liner power for the front stage
would do a blow through in a chevy SSR or an old GMC typhoon. you know, just keep it simple.
(edit: ^ i wanted to mention CM //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif )
i'd have to say 4 Fi SP4 18's 2 to an enclosure, each sub would get 8cubes the enclosures would be tuned to 24hz and each sub would bepowered by 2 Behringer EP 4k's
that **** would destroy.
Major SQL build....
Subs: Four TC Sounds LMS Ultra 18" in an enclosure to play flat from 10hz-80hz
OTHER Subs: In the event I need extra space, I'd swap those subs out and put in a simple Si Mag V4, just to keep bass and save space //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Sub Amp: B2 Audio M1
Speakers: Some sort of 3 way active... Like 8", 3", and Super tweets... two sets on each side.
Speaker amps: Two B2 Quattro for the small speakers... and a B2 Duo for the 8s.
Vehicle: Something big enough to fit everything in, but still able to get decent staging out of...
Obviously it'd need a stripper pole to hold the roof down, and ridiculous amounts of deadener treatment. Two or three alts with plenty of batteries, and of course the system would run at 16v.... Train horns to let people know when their driving like idiots, though I suppose I could just burp it and scare them...
I dunno... I'm just making this up as I go haha. Hopefully it'd sound ok.
Oh, head unit, of course.... I've narrowed that down to 4: Alpine 7998, Alpine 9813, Eclipse 7200, or Pioneer p99rs
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
296
They managed to turn Covid into a wedge issue.
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
07denali
07denali
FL
Full Tilt
chillin
    Jun 14, 2024
