Hayabusa
Audiophile
Which would be best to have the OHM for the sub? 4 OHM, 2 OHM, or 1 OHM. And whats the difference between the 3? Bass wise and etc...
Ok So if my subs are 4 OHM my amp would do fine powering them at 2 OHM?
Your sub is the factor in your impedance... You must have a sub that can create a 2 ohm load. This is the amount of resistance, "usually" lower resistance higher means more power. Just because an amp can run at a 2 ohms doesn't mean it always does/can.Ok So if my subs are 4 OHM my amp would do fine powering them at 2 OHM?
