i think my orion might be broken!!
downwiththeclow
So ive had my 2500d for about 5 months now and it worked perfectly up untill about a month ago. It started doin this thing where if i turned up my volume for longer than a few minutes the subs would turn off, but the amp power light remained on. Its gotten to the point now where if i turn it up at all the subs cut out and the amp may or may not turn off. I thought it might have been an electrical problem so yesterday i replaced my old battery with a redtop and got a new alternator. To my dissapointment the problem is just as bad as it ever was. I have it powering two L7s at one ohm and the gain about 3/4 the way up. Does anyone know what my problem might be? Im startin to think my amp might be bad but i want to be sure what the problem is before i have to buy a new amp.
thanks in advance for any advice you might have
Tough prob.. Conections good? Rcas might be out, try the amp in a diff car. I've bought a blown amp before becasue some kids RCA sender on his HU went out.
you ripped off a kid shame on you //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif :greedy: j/p
Got a Pioneer 4ch out of it. Decent little cheapo workhorse amp. //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif $10 ftw. He rreplaced his headunit because I told him his RCAs were blowing the amps. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
I had that exact same problem with my Slash 500.1 Took it to a local shop and it was the amp that was the problem. I thought all along it was a ground or connection problem. Bought the amp off ebay for only 1 month or so too. Now i have to get a new circuit board for an extra 300$.
no problems with mine....
I had mine for about 6-7 months,no issues
make sure you are feeding it correctly,its not exactly the most effiecent
amp I have ever used..
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
downwiththeclow
downwiththeclow
flower mound, texas
Ignatowski
    May 31, 2024
    May 24, 2024
