I need a little help
Good luck getting a 9104d to put out 800 watts RMS! **Click HERE**
Or read the following:
Kenwood KAC-9104D - Review Amplifiers
TEST RESULTS
Output power @ 1% THD, 100Hz, 14.4 volts
Mono @ 4 ohm 506 watts
Mono @ 2 ohm 644 watts
Mono @ 1 ohm N/A
Output power @ 1% THD, 100Hz, 12.5 volts
Mono @ 4 ohm 444 watts
Mono @ 2 ohm 565 watts
Mono @ 1 ohm N/A
Distortion at rated power, 100Hz, 14.4 volts 0.9% @ 2 ohms
well dat sucks lol.do you have any info on the kenwood 8104D that i use to use ? it said it was 500rms@ 2ohms,which now after reading ur post makes me wonder.
All I know is that a friend of mine manages a shop that sells Memphis products and Kenwood products. Although they mainly try to push Kenwood for the head units, they have to buy a little bit of everything in Kenwood's product line.
Till this day, he said that he has NEVER seen a Kenwood amp make its rated power, and he swears by that statement. Sadly, these amplifiers come with birth sheets that show how they make rated power or a little more at the factory, yet put them on a bench and they will NEVER do it.
If I had to guess, I would say that you are lucky if your 500 watt RMS Kenwood amp gives you 300 or so clean RMS watts.
wow,thanks for that info.and to think before i bought the zx750.1,i was getting 500w lol.no wonder i couldnt blow that cvr with that amp lol.some more good info to know.kenwood amps must truly **** !
moose_guy70
moose_guy70
Yucca Valley, CA
Bass Addict
