How important is dsp?
Hello,
Im getting system installed this week and next it consist of the following in a wrangler jeep
3 polk audio 12s
4 polk audio 6.5s
Polk audio 1200 mono amp
Polk audio 800 4 way amp
Ive had two installers tell me the amp crossovers and kenwood d992 head unit will work and no dsp needed but i want to be sure since the amps will be sunk into floor and covered in plexi glass.
If needed is the audiocontrol dqdx any good?
Sent from my iPhone using Tapatalk Pro
Then why does John Kuthe have a DSP?
Man this question seems to have a million answers. I just want to be positive because once the floor is built the stuff flushed and under plexiglass itll be hatd to add if needed.
I would take Jeff's answer tho.
It's not need, but by choice. Unless you were in a SQ class, then it might be.
Thats same as thing the installers said, only one shop said it was needed. Cant wait to put it in shop saturday. Box design is kinda a cross between these two, plan on having the system and lift done by april 16th as want to enter a show then. .
the one that said its needed, they shouldnt be trusted lol.
you only need a DSP when you actually have tweeters, midbass, midrange and sub which needs proper crossover adjustment and slope and EQ.
right now you just have 4 coaxials and sub which does not need anything other than a head unit in all honesty.
again 4 coaxials is too basic to be making proper use of a dsp.
Thanks man, thats why im glad i found this forum so i can learn, i honestly have no clue what in doing. Will not be entering and sound shows lol just basically a system for me to listen to in the jeep but good enough install to enter car shows where you dont even turn the system on usually
I got GB10, GB25, GB60 in my F350 powered by two JL XD400-4 amps. Next payday getting my Hertz H8, and 4 JL 8w3 with a JL HD1200-1. That will finish up my nice SQ build.
Casa Grande, Arizona
You think it will finish it up. Give yourself. Few months of tuning, tweaking, tuning, tweaking, hearing reverb, fixing reverb, rise, repeat.
You might find yourself aiming those a bit more off axis. You will have to make big cuts in the higher frequencies.
Arledge77
Arledge77
Phoenix, Az
LosIsATool
NorthFramingham
    Jun 30, 2026
