HOW DO I wire AN 8ohm realistic40-102 and a 4ohm Rockford fosgate S1-84 to a PLA2570?
go get a DMM, turn stereo off and measure the OHM value at the amp's speaker terminal and tell me what it reads.
1.8 ohms.. that's a 2ohm nominal load... not 4ohm!
This is why your amp is still going into protect.
Sounds like its not a good amp to begin with. IIRC thats a Pyle amp. Pyle is synonymous for pyle of ****
edit: why are badwords censored when I say them, but others can drop f bombs all day and not get censored and some even have fewer posts than me.
Well I don't exactly have options yet. This is my first system and its going to take time for me upgrade($) and learn this stuff. For now if it works Im happy, and it doesn't. Thank God for the internet, otherwise Id be screwed. Shizzzzon, how do I make it work with what I got?
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
68
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
547
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
898
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
871
Henry De Roche
Henry De Roche
Ishpeming, Michigan, United States
AcidicDreams
    May 16, 2024
    May 16, 2024
