How do I make a system plug into a wall socket (120v)?
Just get a battery charger/tender and keep it hooked up to a car battery and hook everything up from there just like in a car...as long as you aren't playing the heck out of it (if you just have a small charger) it should be fine.
I have a system that I need to be able to run on AC current (house plug). What do I need to make it do this?
don't tell me you're trying to run house stereo equipment in your car..//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
nono....
car subs INTO the house
so he can **** up his whole room wake up every ****ing neighbor and get his house marked *** a party loud annoying house:wow:
So a 200 watt power supply can run a 2200 watt sub amp?
A battery/charger can be used indoors without releasing posionous gas while charging?
Someone who doesn't understand the difference between DC and AC should be told to wire a 12 volt device to a powersupply and wire up the 120 volt connector with no further instructions?
Are you guys going to be there to help put the fire out when he burns his roommates alive?
computer power supplies.
connect the green wire to a black one.
use the yellow and black wires for power and ground.
haha how did yours end up?
Battery with charger isn't a good solution, even with sealed batteries. Computer power supplies can't provide enough current to power much more than a head unit. To do this, you would need one or more DC power supplies. They're not cheap.
false
i have a 25a comp power supply powering a kicker zx1500.1 and im getting ~600w out of it with the gains turned up 1/4 and the bassboost at 1/2 with a bass knob.
dont say things that you havent done or tried.
false
//content.invisioncic.com/y282845/emoticons/ohsnap.gif.17c4c91be09a7a4a3995fb7145adac39.gif
qwerty11
qwerty11
USA
FlexnInLa
