hifonics maxximus vs incriminator audio 40.1
the amps aren't comparable //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
If you have the electrical system to support it, go with the Maxximus.
maxximus=10,000 watt rated amp
40.1=3600 watt rated amp.
Both are underrated. They are not in the same category.
2 40.1's on 18 volts at strapped at .5 ohm (.25 ohm each amp) may be able to keep up with a maxximus.
ok 'cause we all know that a maxximus is just 2 amps strapped into one right?i have heard that the 40.1 can even run at lower impedances than .5 ohm
i don't think that would be too good for the amp for daily or music in general, maybe on a burp or 2, but i still say go with the maxximus if you have the electrical to keep it going.
I'm just a tad curious as to how you ended up comparing these? Spec wise they're very different, and price wise they are world's apart.
The IA 40.1 has a suggested retail of 1400, while the maxximus has a suggested retail of almost 10 grand
because i have heard that the 40.1 is extremelly underrated in fact some competitors told me that the 20.1 and 40.1 where the reason the fuse rule came into place
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
They all say they are in stock but they aren't. Just like my SSA Zcons and Evils were "in stock" but had a super long build time.
ghettoknock
ghettoknock
lebanon
OldSchoolBass-G
    May 24, 2024
    May 23, 2024
