HELP....someone told me to get these?!
well I just baught them...I didnt wanna go over 170 on the subs...so he said these would be perfect....If you could tell me what kind of amp and the amp wattage I need to...it would be very helpfull...
Cause when they arive...be **** sure ill be posting in the wiring section hahaha...less they come with a manual?
I take it they are dual 4 ohm? if so then you need an amp that will do 400-500 x 2 at 2 ohms each channel, or an amp that is 800-1000 at either 1 or 4 ohm mono. rockfordfosgate.com has a wiring subs up that includes pics and is as simple as it gets. BTW what kind of box this going in?
lolol @ box... a standard best buy box....the ones that are made of wood with carpet on them and are slightly angled..than it's goin in the trunk of my cavilier...lmao@ me not knowing anything about anything
Specifications:
Watts MAX. Music Power 800W
Watts Nominal Power Handling 400W
Frequency Response 18 - 2kHz
Sensitivity 89dB (1W/1m)
Ohm Rating 2
Recommended
I'm currently doing an install in a friends lincoln with the next model up of these (ts-w306c)
SVC 4 ohm subs, they will be drinking 250 rms per sub in a 2 cu ft^3 box @ 28 hz, im
waiting for the subs to come in (should be here later today) if you want i can give you a
review before you spend your money. BTW, i purchased 2 of these 12's on ebay for $122.50 shipped...
you may want to check that out
CHECK THIS OUT
my bad i just read the rest of the thread... that sucks but hopefully you won't be
disappointed... i'll PM you with a review once i get it installed if you want i'll send pics
wow im impressed... your friend actually gave you a good recommendation. Pioneer Premier is good stuff.
by the way, make your own ported box. Theyll sound so much better.
I think he should stick with a sealed box if hes going ot make one...he said this is his first system and he doesnt kno anything at all about it...he should learn with this and upgrade later...
just my opinion
ThaPIONEER
-Tha NewB-
ThaPIONEER
Tucson, Az
jujumantb
