Help my sub won't hit high notes
I can make tens hit notes at 25 hz //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I took my subsonic off, then I broke my hatch...
If I turn off my SSF bad things happen. At 20hz the sub will make the entire enclosure and the whole false floor its attached to jump almost a 1/4" (the box is over 100lbs, the sub is 60lbs, the battery on the floor is 60-70lbs, amp is 20lbs, and the entire floor itself is 70-80lbs...so basically around 300lbs)
Im getting 0.91 cuft sealed..Kickers need a bit more than that..They sound so much better ported as well..Id get to 1.4-1.6 cu ft min ported,to get more out of that sub,that could be your issue.What do you think @ Buck?He does not even have 1cuft min sealed?
Dallis
Dallis
Washington IN
oldschool4me
