Help Installing tweeters please
^^^ Yep, a hole saw is your best bet for making a tweeter holes. Get an adaptor that will can be attached to your power tool.
Pay attention to the size of the hole that you need to make, it's usually smaller than the tweeter's flush mount kit's outer gasket. Sometimes a hole saws don't have precise cutting diameters, they usually go from .75" then jump to 1".
I didnt have any precision instruments, so I used a drill to make dozens of little holes around the circumference that I needed, and then used a dremel to cut out the pieces between the holes. Plus, it wasnt a perfect hole so the fit was very tight //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
erik019
erik019
IN
bikejunkie223
Mike Mccabe
